Topic: OT. question about powered usb hubs
Will a powered usb 2.0 hub work if it's power supply adaptor is not connected ?
I mean like a normal hub for the usb ports (power from the computer / switch to power supply -if connected)
Someone with a powered usb hub can tell.
geposted Wed 17 May 06 @ 6:52 pm
i sincerly doubt it if it's powered that means it doesnt take it's power from the pc at all so it need it's adapter all my usb peripherals that have an adapter will not work without it being hooked up that hub has a power adapter to protect ur pc from too many devices drawing power from it ( if all the hubs are taking)
Yes, it will work as a port, but will draw it's power from the machine. This defeats the purpose. I got a powered hub, so my stuff would not draw any more power from the machine. My new video card wanted more power then my power supply had. The reviews of others, said it ran fine on their machines, with less power then I have. I can not change my power supply, so I got a powered port, to take some of the load off. So, If you have enough power, you don't need a powered usb port, it will work without the adapter.
Ok, so a powered hub can operate like a normal hub, and usb devices take power from pc if the adapter is not connected right ?
But what happen if you plug the hub's power adapter while a usb device is already connected
(lets say a usb keyboard), will the power source switched automatically or is not recommended to do this "on the fly"...?
Any success story with a usb souncard (maya) and a hub ?
(as usb souncards usually don't work well with hubs...)
maya 44 works fine with powered hub.
it's not recommended to unplug power ftom powered hub ;) i did once when i had connected usb disk. It get bad sectors. don't know why...
Good to know that...
Thanks for the answers i will try a usb hub tomorrow.
Normal USB port provides 5V/500mA max the device should not take more than this. If you connect USB hub (powered) but all devices connected to it ,with the hub itself, take less that 500mA together it should work without power adapter.
At least it works for me.
Also I modified my DAC 2 so it does not have big aluminium cooler and stabilisator from 12 to 5 V. Now i use 5V from my USB (even if its some 700mA) my notebook handles it good, without any hub... So one less adapter to carry for me :-) I plan to make a flatter case for DAC.
Interesting what you did to your dac, wait to see what i'm doing to mine...
when a box will be done I'll post pics in my blog
