Topic: can i mix l
hi im going to by the softwear but im looking around but im worndering can i mix wit turn tables like this
http://www.rane.com/SeratoScratchLive_High.mov
if so what do i need to get the so mix like that if i was to buy virtual dj
what would i buy i have one sound card wit mic input and headphone output
geposted Wed 17 May 06 @ 11:54 pm
Yes vdj can but unfortunately the vids on show arent as extensively produced as that.
Check the link below.
http://www.virtualdj.com/download/virtualdj_by_dj_getdown.wmv
To utilise the timecoded vinyls you will need a 4 channel input soundcard. The soundcard recommended by VDJ is the Maya44. Do a search in the forum for more details, theres plenty of answers available.
Virtual dj works with timecode vinyls/cd's and controllers.
Btw. no need to post the same question 3 times...
will it work wit any vinyl's or what
1) i can buy turntables here in detroit for 100$
2) a mixer for 100$
3) dont no were to get the "Maya44"
but that all i would need
Yes you will need that and a computer of course with a decent amount of Ram (512 and up is recommended for Time coded vinyl). As far as any vinyl, you need the Virtual DJ Timecoded Vinyl ordered through this site. You can also use a bypass feature to play regular vinyl records by bypassing the software. The Maya 44 can be bought at musiciansfriend.com or other places that sell professional soundcards. You can also use other soundcards such as the ESI U46DJ card.
to have a better idea you can have a look on our material that we use with VDJ. the most of us have turnatables , mixers, maya, so when if u need any help ask us anytime ;) aight ?
Angel
