Topic: Time Remaining
Hi,
Don't mean to flood this forum with loads of newbie questions!
Anyway, I've just loaded two tunes into VDJ.
The track lengths are 6:19 and 8:21.
When I'm right at the start of the track however, it says time remaining 5:59 and 8:03.
When the 1st tune ends it says time remaining -20 and the 2nd says -18.
How can this be? Surely at the very end of the track time remaining should always be 0secs?
Thanks
geposted Tue 23 May 06 @ 2:18 pm
Are they encoded in VBR ?
No the bit rate is 256 and 320kbps respectively.
Weird... I never experienced that...
try on another computer. it happened to me once on desktop (v2.1) :)
but i think there is something wrong with songs.
before you think it's the encoding try to do a full anaylise of the songs (not techno/hiphop) if it still does it then transcode them
Would the que points from analying cause the track length to be shorter. I will have to look at it. I know that on some songs it might intro 1/3 of the way in. Something worth looking at.
