Forum: Wishes and new features
Topic: Sampler in V 2
I recently visited this site:
http://www.looplabs.com
It's a very nice site where you can find an online sampler.
Maybe it's possible to add some functions, as shown there, to the VDJ Sampler:
Mute, Solo, Pan, Drag & Drop.
It's great that sampler has been synchronised but sometimes it's just a bit off. That's not a big issue if you are using the sampler only for short lyrics. But it will be an issue if you look further towards the live remixing part of the sampler.
A selectable nudge function on the sample would be great.
Also a selectable skip beat function on the sample would do the trick.
I don't know if the "skip beat" and "nudge" functions are incorporated in the UC33e Mixtable but I think they are quite useful.
Let me know what you guys think of it!
GnoedeL
geposted Sun 13 Jun 04 @ 4:17 pm
Hi GnoedeL
I notised too that the sync was a bit off, when using sampler on a song...
But then I realized the problem (at least for me)...
sampler is beatlocked to song, with the beatlock feature. And that feature depends on a few things:
(1) Right calculated BMP for that song AND sampler (loop)
(2) That CBG is EXACTLY under beat in song AND sampler (loop)
If u adjust that (usually sampler is ok) for the song you are playing - pressing the CBG arrow so that its just under the beat, there is NO sync problem :) that fixes it...
You can try yourself move the CBG a little bit off the beat, and hear the opposite effect :)
Hope that helps....
dj in norway
I'll give it a try, thanks!
Still nudge or other sampler functions would be cool :)
