Topic: Skins With Three Tables
Anybody know any skins with three tables. When I run two windows it freezes any help?
geposted Thu 25 May 06 @ 3:52 am
erxonPRO InfinityMember since 2003
1/ Always search the forums before posting, the same question has been answerd a week ago.
2/ it shouldn't freeze when using more than one instance of VDj. I also don't know if the demo version allows more than one instance, it works with full version though.
geposted Thu 25 May 06 @ 9:32 am
phillydjPRO InfinityModeratorMember since 2004
works perfect in the full version so if you like the program enough to run multi instance please buy it
geposted Thu 25 May 06 @ 5:38 pm
erxon, I tried searching all the forums for "three", but without luck. I too would like a skin with three decks - using two instances of VDJ seems a bit stupid and ruins my overview.
Please give us a link to the thread you mentioned.
geposted Fri 26 May 06 @ 12:13 am
Junker Juks,
unfortunately there is not a skin with three decks. There are only skins with 2 or 4 decks. Look in the skin download page. The "Multi-Instance Skin reloaded v1.5" from DJ Cel has 4 decks.
Ewout
geposted Fri 26 May 06 @ 12:57 am
d rocksPRO InfinityMember since 2006
when iwas test driving it, seems like years ago now, I am sure that I ran multiple instances. I was trying to see if I could get 2 video outputs from vdj and I am sure that it worked. Hey maybe v.4 will take care of this;).
If you are thinking you need more than 2 decks this is the software you need, with the multi deck skin. Maybe jump on it now before the $ go up.
geposted Fri 26 May 06 @ 4:05 am
@Junker Juks:
Exactly what Ewout (Superstom) said few posts above was the answer to that thread :) VDj currently engine has only two "audio players" (apart from samples), so it's impossible to make a skin with 3.
Might change in future versions, if VDj team will see the use of it.
geposted Fri 26 May 06 @ 9:54 am
