Topic: Default sort by BPM?
Is there a way to sort my song lists by BPM?
I know if I hit the BPM tab it will sort chronilogically, but I'd like to have the BPM sort as the default in every song list and playlist I open.
Is there a way to do this?
Thanks in advance...
Sirslick
geposted Thu 25 May 06 @ 6:57 pm
You could default sort by BPM:
- Close VDJ
- Open the windows registry (Click start->Select Run-> Type Regedit-> hit enter)
- Browse to "My Computer->Hkey_local_machine->Software->VirtualDJ"
- Select the "Autosort" key. Change the value from 0 to 3 (hexadecimal).
- Close the registry
- Open VDJ
note:
Value 1 = Sort by Title
Value 2 = Sort by Author
Value 3 = Sort by BPM
note 2:
modifiying the windows registry could harm your computer. Make sure you have a backup of all your important files, before any modification
Ewout
Thanks!
I'll give this a try...
Sirslick
