Hi,
Ok, this is my current set up:
2 x decks
1 x mixer
1 x hi-fi
1 x laptop
I want to link my decks to my mixer, then my mixer to my laptop so I can use VDJ with TCV but also my viynl. I want to use my mixer to mix, not an external MP3 mixer like the Hercules. Could anyone advise on a decent, relaltivly cheap external soundcard that I could use? I've eBayed and Googled but still have no solid results. Also, I'm from the UK so nothing thats USA sourced please (thats all I could find searching the forums). Does anyone have this setup running?
Thanks in advance for any help.
(p.s I haven't bought VDJ as I want to know if I can run this setup - hence none reg user)
2 x decks
1 x mixer
1 x hi-fi
1 x laptop
geposted Fri 26 May 06 @ 11:51 pm
Of course you can. Look here: http://www.virtualdj.com/blog/Dams/blog738.html
you need only maya44 usb AND VirtualDJ pro.
geposted Sat 27 May 06 @ 11:22 am
Ok, thanks for the reply. I'll go for the Maya.
Oh, and the Blog link doesnt work.
geposted Sat 27 May 06 @ 4:29 pm
maybe it doesn't because you don't have VDJ registered :) it works for me ;)
buy VDJ pro and may44 USB.
And you will need Y-splitters to use normal vinyls too, or you can set function in VDJ to bypass the signal of normal vinyls.
geposted Sat 27 May 06 @ 4:35 pm
Thanks Xeon. I picked one up for about £77 from www.makingwavesaudio.com. I'll get VDJ Pro when it comes through!
geposted Sat 27 May 06 @ 5:35 pm
Well.. you are welcome ;)
hope to see you as full member soon ;)
geposted Sat 27 May 06 @ 5:44 pm
