Everything was good until yestarday. I noticed that the track titles were not showing up in VDJ. I could search by the track and would get the song (without track title). I checked the track in explorer, everything appears ok. When checking within VDJ (file info) the track title was changed to Track 6 . This happened to quite a few tracks. I tried to reinstall the XML database from last Sunday, but it di did not correct the problem. Suggestions on why this could have happened and how to avoid it in the future?
geposted Sat 27 May 06 @ 1:43 pm
Did you by chance turn on the READ ID3Tags to 'Title'?
I know that if the ID3 tag for a track has the title missing or in correct info like Track #, then what you are seeing could be from activating the READ ID3Tag in the General Tab.
cstoll
cstoll
geposted Sun 28 May 06 @ 5:09 am
ID read tags were off. AFter this happened I turned read on. That did not help. These trks were previously showing correctly. ALso now if I rename a trk within VDJ it won't change. I must scan database after renaming each trk.
geposted Sun 28 May 06 @ 1:40 pm
