Forum: Wishes and new features
Topic: mixman DM2 Support - Page: 1
sbangsPRO InfinityMember since 2004
hi there i think it would be cool if Vdj could support this controler
as i think it would attract alot more beginers to virtual dj as it now only costs 29.99 £
maybe it could be included in the next home edition?
until then any one reading this should use the DM2 to midi mapper , http://www.pdoom.ch/dm2
geposted Sun 28 May 06 @ 12:42 pm
I've got DM2. How do I use it with virtual DJ?
geposted Sat 10 Jun 06 @ 7:11 pm
i found a mapper on the web that some one wrote , il try and upload it soon.
in the mean time try using www.pdoom.ch/dm2/
and making your own shortcuts.
geposted Mon 12 Jun 06 @ 11:29 am
the problem with that mapper is, that it's not possible to get the scratch functions working correctly over Midi...
the collegues at Mixvibes do have DM2 support, but you don't want to use that ;)
geposted Mon 03 Jul 06 @ 8:40 pm
metiznPRO InfinityMember since 2005
DM2 support would be great!!!
geposted Tue 04 Jul 06 @ 11:57 pm
i used to use mix vibes but it is very pricey and has only 1/4 the features of vdj
so.....
geposted Fri 07 Jul 06 @ 1:38 pm
geposted Wed 01 Nov 06 @ 11:33 pm
you must be a pro user and have 3.4 for this to work..
thought that some people may be interested
so posted this info :)
geposted Wed 01 Nov 06 @ 11:34 pm
if your exceptionly midi smart you might be able to get it working in v4.0 im still looking at it
geposted Thu 02 Nov 06 @ 12:02 am
So, does scratching work now with this controller on version 4.x?
geposted Wed 15 Nov 06 @ 10:00 pm
v4 is not supported yet
geposted Wed 15 Nov 06 @ 10:07 pm
geposted Sun 19 Nov 06 @ 11:26 pm
So has anyone actually been able to get teh DM2 to work with 3.4? And is it worth the extra effort and time to set it up? Or should I just buy the Hercules console?
geposted Thu 28 Dec 06 @ 2:00 am
i made a mapper of sorts for pro users
you can see it on the tools download page
personaly id get the mk2 tho ;)
geposted Thu 28 Dec 06 @ 1:05 pm
DJDTCHome userMember since 2006
can any one help me in obtaining the dm2 software, i have the console but i can't do anything with it without the software. Its pretty hard to find, I would appreciate very much if you guys could tell me where to get this software.
geposted Tue 20 Feb 07 @ 11:13 pm
contact digital blue support the makers of the dm2 for drivers.
geposted Wed 21 Feb 07 @ 10:09 am
What's the link for getting the console dm2?
geposted Sat 17 Mar 07 @ 2:46 am
the mapper or the consoles shop?
geposted Sat 17 Mar 07 @ 10:40 am
The console
geposted Mon 19 Mar 07 @ 5:57 pm
geposted Mon 19 Mar 07 @ 7:54 pm
83%
