Topic: Second Gig...what happened.
NAWTBOYPRO InfinityMember since 2003
Ok so i used it again this weekend....6 hour gig. A few times the effects started engaging themselves. I had a break effect loaded on each deck and for some reason the songs decided to break on there own....
The BEATLOCK started driving me crazy a few times.....after you fade over you have to remember to uncheck the beatlock on the side playing because if u load a new song and hit play to cue the song playing will jump up or down in speed. At the beginning of the night i was fine but as a few drinks got into me i forgot and i had a couple songs jump from like 143 BPM to 135....a drastic difference....
and lastly......a couple times when i would have the beatlock on i would hit play and the Tempo's would be the same but the BPM sprokets were not lining up....they were exactly a half beat off...
geposted Mon 14 Jun 04 @ 1:55 pm
djzeroPRO InfinityMember since 2003
did you have any shortcuts assigned to your effects? you may have been hitting the shortcut key by accident after your few drinks...
geposted Mon 14 Jun 04 @ 2:08 pm
NOPE....NO EFFECT SHORTCUTS......i thought the same thing
geposted Mon 14 Jun 04 @ 5:23 pm
mp3jrickPRO InfinityHonorary MemberMember since 2003
See if that happens when you are drinking water..........LOL.
geposted Mon 14 Jun 04 @ 7:15 pm
