i was wondering if anyone knows how to change the voice from like really deep to really high?????
geposted Wed 31 May 06 @ 10:19 pm
If you're talking about the vocals of a song, then there is no easy way to do that without changing the pitch of the music as well, unless you have the vocals and instrumentals separated into separate tracks.
To change the pitch in VDJ, just make sure that 'Timestretch' is turned off and then move the pitch slider. As I said, this will change the pitch of the entire track though. Be aware that this will also change the tempo.
geposted Wed 31 May 06 @ 10:40 pm
There is also a key change plugin available, but you have to be a registered user in order to download it
geposted Wed 31 May 06 @ 11:27 pm
Can you give me the link for this plugin i cant find it.
geposted Thu 01 Jun 06 @ 12:04 am
hola
geposted Thu 01 Jun 06 @ 12:12 am
Ok i have found it:)
geposted Thu 01 Jun 06 @ 2:19 am
you can use the voice controler2.3\
geposted Thu 01 Jun 06 @ 11:43 am
You can use a VST effect for this ;-)
see the VST section on this forum for more informations.
geposted Sun 04 Jun 06 @ 3:28 am
Somebody kicked me in the crotch last week, that seemed to work... ;-)
geposted Mon 05 Jun 06 @ 12:28 pm
geposted Mon 05 Jun 06 @ 12:38 pm
