yeh, i just got v-dj 2.0, kinda keen using it, but the downside is when i make a loop/sample from mp3 or wav in sample mode, i save the loop then try to retrieve it later on, and it just says (empty) and not playable where all the other default samples have the name of them underneath and they are playable all the time, whats happened, does anyone have same problem. pls help
regards mike-d
regards mike-d
geposted Mon 05 Jun 06 @ 4:59 am
You need to upgrade/purchase the latest version 3.4.
2.0 had a bug with the sampler and it's been fixed.
geposted Tue 06 Jun 06 @ 6:15 am
i'll up my game then, thanx pal
geposted Tue 06 Jun 06 @ 10:43 pm
