Topic: how do i program a slow crossfade?
i programmed a shortcut key that will immedietly crossfade to the other deck and start playing, but how do i program a "slow" crossfade to the other side, is there a "delay" command to put in between "increment" commands? thanx
geposted Mon 05 Jun 06 @ 10:40 pm
If you put in +128, it will move to the right in increments, as long as you have you finger on the key. You can use a smaller number, and it will be slower. Using a - number, moves it to the left.
