I guess I have to select audio and video events in order that when I move the pitch they both (audio and video) get syncrhonicity,right?
geposted Wed 14 Jun 06 @ 6:13 pm
Sorry I didn't get back to you last night reg. Okay here we go.... If you are bringing a video into Vegas and you want to timestrech or compress, just click on the tail of the audio or video event while holding down the CTRL key and drag. (Video events are grouped with the associated audio so it doesn't matter which event you drag.) By default, Vegas will change the time without changing the pitch. If you want it to change the pitch just tick the "Lock to stretch" checkbox. Depending on how much you are changing the tempo you may need to play around with the "Stretch Atrributes" so that you don't get echos and things like that.
geposted Thu 15 Jun 06 @ 12:50 am
ok, so by doing this, video follows the pitch of the audio and you can mix several videos using their own audio? cause so far what I do is to mix the audio in acid pro first, so then I open vegas I cut my events in order that video fits with audio.
geposted Thu 15 Jun 06 @ 1:18 am
Yep you got it!
geposted Thu 15 Jun 06 @ 3:33 am
Well, I can't stretch audio and video, I thick lock stretch in audio properties and when I move the pitch video still remains in the same speed and delays more than audio, cand you send me a picture about how to do this? thanks, Manquin DJ
geposted Fri 16 Jun 06 @ 5:10 pm
Sounds like you are bringing your video and audio in seperately. In that case, what you need to do is group the audio and video together. To group multiple events together just click on each of them while holding down the CTRL key then press the 'G' key. After grouping the events moving, stretching, or deleting one event will do it do them all. To ungroup an event, just select it and press 'U'. If this still isn't working for you, email me. I'll send you some sceenshots if that will help.
geposted Fri 16 Jun 06 @ 8:28 pm
ok, I'm gonna check it , thanks for your time!
geposted Sat 17 Jun 06 @ 12:20 am
I guess I have to wait for new version in order to see if to mix using pitch within vegas is possible for audio and video together, for my video mixes would be easier to mix in vegas wihout using acid pro, thanks everybody, Manquin DJ.
geposted Tue 20 Jun 06 @ 2:55 am
I guess I should've asked, which version are you using?
geposted Tue 20 Jun 06 @ 1:10 pm
I'm using version 6 but I don't know what built it is.
geposted Wed 21 Jun 06 @ 5:38 pm
You are using the same version I am! This might be something that I can help you with better over the phone. I'll PM you my number and we can work out your problem. (I have a toll free number for my production service.)
geposted Wed 21 Jun 06 @ 7:45 pm
Ok anyway if you don't mind you can send me screenshots and I guess that would be enough, thanks a lot.
geposted Wed 21 Jun 06 @ 9:05 pm
