Polling whoever wants to answer: What settings do you all have for the "nudge" commands? As in, what magnitude of nudge do you use? I have 4 different ones, set at: 1000, 500, 100, and 10.
Depending on the tracks I'm mixing, different degrees of fine-nudging are required... For some, the tracks are so similar sounding, that the 500 nudger will get it in there as close as necessary -- for others, even the 10 can't quite get them to match perfectly, and EQ'ing is necessary to avoid b-bump b-bump sounds...
Check out my newest mix!
Play: http://www.musicv2.com/process_stream.php?id=20497
Download: http://www.musicv2.com/download_cue.php?id=20497
geposted Wed 14 Jun 06 @ 7:08 pm
Nobody wants to share how they have their VDJ nudge-ing set up? Come on, someone give me a response! :) Just reply with a number, or series of numbers, no complete sentences or ettiquette of any kind necessary :)
geposted Wed 14 Jun 06 @ 10:06 pm
50
geposted Thu 15 Jun 06 @ 12:24 pm
Totyo please read again BBCode disclaimer, or you won't be able to use it anymore. big, red color wasn't needed here.
geposted Thu 15 Jun 06 @ 12:58 pm
Sorry, sorry, please forgive me
geposted Thu 15 Jun 06 @ 1:37 pm
maybe you should remove the bb code example "look at me"
just copy, paste, it was so easy
geposted Thu 15 Jun 06 @ 1:39 pm
How come nobody else is willing to talk about how they have VDJ configured? I don't understand, seems like an important and relevant issue... So once again, requesting information, what "nudge" values do you guys use?? :) (And don't use big red numbers to respond, haha)
geposted Thu 15 Jun 06 @ 7:56 pm
