Topic: order of songs in a folder
Hello,
Most of my mp3's are organised in albums. Each album ive ripped from my cd's is its own folder. When I open a folder in the side list though, virtual dj lists the tracks alphabetically. However, I would like them listed in the order they appear on the album. How do i get the program to do this?
Thanks,
Ness
geposted Thu 22 Jun 06 @ 1:21 am
xeonPRO InfinityModeratorMember since 2004
If you open every folder (name of album) you will get listed all files in that folder (again from a to z or by lenght or bpm). You can't see all files from all folders sorted by folder (so Album if you don't have ID3 tags) at the moment. Maybe VDJ v4 will have feature to sort by album, artist, title., year, and maybe even folders. At the moment (v3.4) you should open each folder to get songs of this album.
geposted Thu 22 Jun 06 @ 10:37 am
The best solution is to look at the original CD, then create a playlist from that album with the songs in order that they appear (or just play them) - providing you don't leave any off, when you click on the spot thing at the left, it will display the tracks in the order they have played them - as long as you play it like that every time, it should do it. If you save them in a playlist in the order they are on the album, it should play it like that every time.
geposted Fri 23 Jun 06 @ 11:33 am
