Topic: midi mapping the jog wheels.
right ive bought myself a xone 3d and im currently mapping it to vdj. now im having trouble mapping the jog wheels and the rotatries.
the jog wheels will only go forward, if i spin them backwards it just spins forward in scratch mode if i spen forwards it just goes forward in nudge mode.
is the a specific setting i need to set it to as im lost, there are a number of options on the mapper in vdj config, but i cant seem to get it to work at all.
same goes for the rotary pots they will only give me maximum values, i.e. if i set a rotarty to be the pitch know like on the hercules, instead of going up in.01 of a beat each notch as i turn it, the value just goes to the maximum or minimum.
help please as i dont have a clue. thanks.
geposted Thu 22 Jun 06 @ 4:56 am
So you have tried using map 1 and map 2 settings in the config utility?
no, so im assuming map one is set to ableton mode hence the way the jogs are working and map2 is in traktor mode?
sounds good, ill let you know if it works. you got a 3d too? dont spose youve a map already done?
i just got my xone 3d on july 6th. i have the same problem. vdj 3.4 doesnt understand the midi from the xone 3d's jog wheels and rotary encoders. a midi translator might be a workaround but i dont know how to configure it.
