Right first off, i've searched high & low on the forum with regards to setting up the U46DJ
I have a U46DJ & a maya44 which the latter i can work in vdj perfectly well.
Downloaded latest drivers for the U46J & still can't get it to work.
How i want it to work is player A using outputs 1 & 2 so that its in stereo & player B using outputs 3 & 4 so that is in stereo too.
Don't get me wrong when i say this but PCDJ FX is easier to set up the configuration for soundcards which i used the U46DJ for the two players & the karaoke player.
Any help in this matter would be great.
Thanks in advance
DJ Craig E
Thanks in advance
DJ Craig E
geposted Fri 23 Jun 06 @ 9:09 pm
Craig I don't know if you know this but there is a forum dealing with hardware issues only, this forum is just for General discussion. I just did a search in the Hardware forum and found this
http://www.virtualdj.com/forums/46315/Hardware_Technical_Support/U46DJ_Setup_-_HELP___.html?highlight=u46dj
There other posts regarding your soundcard as well
geposted Sat 24 Jun 06 @ 1:56 am
Thanks for that. i just know earlier when i clicked on that part of the forum nothing came up.
Regards
Craig
Regards
Craig
geposted Sat 24 Jun 06 @ 2:06 am
