Topic: corrupt installation?
i have a virtual dj software.. i reformat my computer so i repeat the installation.. and a pop up window comes and it say I/O error corrupt installation..? help guys! tnx
geposted Sat 24 Jun 06 @ 10:25 am
xeonPRO InfinityModeratorMember since 2004
Uninstall it, delete VDJ folder from Program Files and then download new trial version and install it.
geposted Sat 24 Jun 06 @ 12:09 pm
If what you are using is a "cracked version" you will always have that kind of problems, since the same problem had another demo user and it was because of the pirate version, buy vdj pro and you won't regret, Manquin DJ.
http://www.virtualdj.com/purchase/
geposted Sat 24 Jun 06 @ 5:05 pm
