Topic: using headphones with virtual dj
well i still havent just yet bought the virtual dj software.
just wondering about the headphone volume
what does one hear through the headphones, bot decks a and b.
how does one choose which virutal deck will go to the headphones.
geposted Sun 25 Jun 06 @ 8:59 pm
Just like using a real mixer you can listen to either deck a, deck b or anywhere in between both decks. The only thing which I am not sure about is if you can hear deck a through the left ear and deck b through the right, although I prefer both channels through both cans anyway.
You will hear the active deck through the headphones (which you can change( but you can get skins which feature variable amounts of each channel too.
geposted Sun 25 Jun 06 @ 9:03 pm
there doesnt seem to be a crossfader for the headphones like there is on TRAKTOR, FOR INSTANCE
geposted Sun 25 Jun 06 @ 9:14 pm
It depends which skin you use, for example, this skin does have a headphone crossfader. You can download the skin and use it with the trial version to see for yourself but unfortunately the trial version does not support headphone prelistening.
geposted Sun 25 Jun 06 @ 9:27 pm
normally when you load up a new song your headphones split automaticly and throws the new song into your left ear. My speakers however sends it to the right but I just swap the phones around which is fine by me. the main plays in the other ear piece.
Best Regards
DJ White Devil
PS. I use the Mix Station V4 skin
geposted Sun 25 Jun 06 @ 9:32 pm
gees that skin you mentioned is very nice
also i will use soundblaster audigy value 2 which has 7.1.
i guess i should not have any problems as i would chose the 4.1 soundcard confiuration choice.
is that correct.
if so that should make me buy it straight away.
geposted Sun 25 Jun 06 @ 9:54 pm
That's correct, you would choose the 4.1 configuration and enable the extra output 7.1 option which will be displayed.
geposted Sun 25 Jun 06 @ 9:59 pm
is that skin free
geposted Sun 25 Jun 06 @ 10:04 pm
All plugins, skins, effects and samples on this site are free for professional users (this is basically the web download version). Similarly, the v4 update which promises major improvements will also be a free update for existing professional users, so it's a good time to buy while the special offer price is still available.
Most of the skins are free to demo users too.
geposted Sun 25 Jun 06 @ 10:06 pm
