Hi
Dont know if any of you guys have experienced the same problem,Two days ago my Virtual dj just would not open keeps on telling me fatal error press recover ,when i do that it just switches of, i then asked for another application so i could re install but i am coming up with the same problem after i re installed.. Any suggestion??
Thanks Musicmatch
Thanks Musicmatch
geposted Sun 25 Jun 06 @ 10:20 pm
geposted Sun 25 Jun 06 @ 10:50 pm
Hi Support team
I have figured the problem out i went into the compatabilty setting ,set it in windows 95 and the problem is fixed, i thought that if i was running Xp it would run in 2000 not 95.
Anyway if any one comes up with the problem i did there is your answer..
Thanks once again support team for quick responce
Cheers Musicmatch
Cheers Musicmatch
geposted Sun 25 Jun 06 @ 10:56 pm
