My poor old Sennheisers are about to crumble out of hands after nearly 10 years of faithful service, so it's time to change.
I've narrowed it down to either the Sennheiser HD 280 or the Sony MDR-V700DJ
I know there's a few post already relating to this, but as some of them are a little old, I thought I'd just see what you guys are using right now.
geposted Mon 26 Jun 06 @ 12:53 pm
in this moment I'm using stanton headphone like this: http://www.strumentimusicali.net/product_info.php/cPath/117_118/products_id/2999/cuffie_per_dj/stanton-albertino-black-ltd-cuffie-per-dj.html
but, I'd rather to have this: http://www.strumentimusicali.net/product_info.php/cPath/117_118/products_id/3333/cuffie-per-dj/pioneer-hdj1000-cuffia-per-dj.html
bye
bye
geposted Mon 26 Jun 06 @ 1:11 pm
geposted Mon 26 Jun 06 @ 1:31 pm
I'm using the Sennheiser HD-25 every part is replacable.
geposted Mon 26 Jun 06 @ 5:45 pm
I used to have Stanton pro-60 very cheap headphones but the sound was incredible, but unfortunately they blew out, they don't have the capability of handling to much power.
Now I just bought Pioneer HDJ-1000 and the sound is outstanding, very crisp and clear and they do can take a lot of power.
geposted Mon 26 Jun 06 @ 6:23 pm
After many years of using Sennheiser, i'd not use anything else. The Sennheiser HD 280 is probably unbeatable in my book.
One thing I notice now, though, is that when using VDJ I use headphones a lot less because I can see the beatmatch on the screen.
geposted Mon 26 Jun 06 @ 7:05 pm
Sony MDR-V700, just won't let me down!
Had some cheap IXOS ones, well there were Ministry of Sound branded, but made by IXOS, and for the price they were unbeatable! but sony's if you have the cash.
geposted Mon 26 Jun 06 @ 11:33 pm
I'm using Pioneer HDJ1000 but I'm not very satisfied about it. After 6 months they have broked: first the left side than the right side. I had to glue them :(
geposted Tue 27 Jun 06 @ 12:41 am
I use Behringer HPX-2000, it's cheap (25 euros), good sound and strong built. I have them for a year and they look like new!
About Sony MDR-700DJ, they are nice and everybody use them (famous Dj's), BUT take a look at this:
http://www.djdeals.com/sonyMDRV700.htm
Even Dj Deals don't recommend to buy them because they brake so easy, it's unbealivable!! The same goes for Pioneer HDJ1000 as mariushallangos said, they are nice and good sound, but so brakeable!
If you don't have much money go for Behringer like I do, but if you want to spend more like Sony 700 and Pioneer 1000 price range (more than 100 euros), than go for the Technics RP-DH1200 > http://www.djdeals.com/technicsRPDH1200.htm
geposted Tue 27 Jun 06 @ 1:54 am
Well, I have tried a few, but then I got the idea to plug an FM Modulator into the headphone Jack and use a set of RaceTunes made by Peltor (Same as WorkTunes but without the extra input jack). They are ear muffs that you would wear at the Drag Strip with a built in AM/FM radio. By doing so, I filter out most of the external noise and do not have to crank the volume up to hear. I bought a second set so if I need to have someone else listen, I do not have to give them the ones that I wear. Now I am no longer tethered to the console!
Just my two head cents worth. :)
geposted Sat 01 Jul 06 @ 9:34 pm
I'm using sony mdr-v150's, they're excellent headphones for the price range (around $15 USD on amnazon);^]
geposted Sat 01 Jul 06 @ 9:45 pm
Technics RP DJ1210
http://www.decks.co.uk/products/headphones/technics/rpdj1210
geposted Sat 01 Jul 06 @ 10:14 pm
I agree with dj-in-norway...I use Technics RP DJ1200 but...the TOP...at least for me...I have a system HI-FI in the headphone...truly spectacular...you the council...
geposted Sun 02 Jul 06 @ 1:03 am
I have Behringer HPX-2000, only 25e and I'm happy with it. Good sound, strong bass, but a little heavy. They are strong tough, after one year of use like new ;) !
geposted Sun 02 Jul 06 @ 3:46 am
I also use the Technics and I like them a lot.
Ewout
Ewout
geposted Sun 02 Jul 06 @ 2:11 pm
I use Pioneer HDJ1000s
and @ mariushallangos
if those headphones are still under warranty ship them back cause they broke. Pioneer will exchange the casing. Unlike Numark that refuses to fix their crap although ALL headphones break eventually.
So far Pioneer has been treating me very well.
Best Regards
DJ White Devil
Best Regards
DJ White Devil
geposted Mon 03 Jul 06 @ 12:08 am
Sennheiser HD-25 http://www.sennheiser.com/sennheiser/icm_eng.nsf/root/02976
I'm using them since 7 years ago. They don't colorize the sound, great for mastering too.
geposted Mon 03 Jul 06 @ 2:13 pm
Sennheiser HD-25 for me too.
geposted Tue 04 Jul 06 @ 4:25 am
