Topic: sound drops in mpeg
I have been using #1 DVD Ripper to create all my mpeg's and using the default settings. I am slowly building the library. All seem to work fine except I have run into a problem with one disc. Rob Zombies Past, Present, Future DVD. When playing the video back through VDJ or WMP the audio drops in and out. The video plays fine. In VDJ you can see where there is no audio on the graph. The disc came out in 2003 I beleive. I have done a search on the board for #1 DVD Ripper, but could not find any similar problems. Any help would be greatly appreciated.
geposted Wed 28 Jun 06 @ 2:52 pm
DJ CyderPRO InfinityModeratorMember since 2003
try dvd decrypter
geposted Wed 28 Jun 06 @ 3:10 pm
Have you tried playing the video directly from the disc and seeing if the audio still drops out then, it could be a physical error.
geposted Wed 28 Jun 06 @ 3:41 pm
DVD plays fine in other players. I just got the DVD Decrypter. I will have to play with that a little bit. It is not as straight forward as #1 DVD Ripper. How do you set up DVD Decryptor to create mpeg's. I will keep trying to figure it out. Any other help out there.
geposted Wed 28 Jun 06 @ 11:49 pm
