Topic: cant get the headphones going on virtualdj-am i silly????
well.
i have soundblaster audigy 2.
it certainly has 3 stereo outputs.
the first 2 are green and black.
i have the speakers on green of my soundcard
and have put the headphones in the black socket.
well nothing comes out of the black stereo outs for the headphones.
I have clicked on the 4.1 in the configuration and clicked on 7.1 and not the 3D choice.
now what should i do next??
can anyone help
geposted Fri 30 Jun 06 @ 11:45 am
Exit virtualDJ
try to change your soundcard setting in windows control pannel.
If it's set to 2 speakers set it to 5.1 or 7.1.
run VirtualDJ
a funny thing happened
i changed skinfrom the bluish default to the black one and all seemed to work okay, with the headphones mix and its volume choices on the left top.
then i tried another skin and it all went funny again
