Topic: Recording Samples / Loops
Is there anyway to increase the length of the loops that are recorded? I know you can record as much as you want in a jingle, but i don't want to have to keep hitting the play button. Any suggestions?
geposted Wed 05 Jul 06 @ 11:01 pm
just make a look as long as you want.... at the song you are playing
then record it in a sample slot ;) by pressing the "loop" icon
Easy as that
Thanks for that, i had tryed that before and didn't work for some reason, but got it to work now, thanks!
If you simply redord LOOP it records 4 or 8 beats (don't remember now)
But if you have selected LOOP in a player, you can increase the LOOP size and the when you record LOOP at SAMPLE section is the long you did the LOOP at PLAYER.
(Many LLOP word here, hope you understand)
