Forum: VirtualDJ Skins
Topic: MOTOR PRO V3 Skin Missing?
vailixiPRO InfinityMember since 2005
What happened to this skin? I can't find it in the Download->Skins section anymore.
geposted Fri 07 Jul 06 @ 11:42 pm
djjbPRO InfinityMember since 2004
al the tracktor skins are gone from the download-page.
if you search this forum you find out why.
geposted Sat 08 Jul 06 @ 7:09 am
That's too bad! The MOTOR PRO v3 is very, very professional. For me, it continues to be the balance between form and functionality for VDJ skins. It's the skin that drew me to Virtual Dj. Else, I would still be using Traktor. I still use MOTOR PRO with VDJ 3.4 for all my gigs and have found it to be the best.
(A question to the support team). When VDJ 4 comes out and I run the update, will i still be able to use my MOTOR PRO skin? Please let me know in advance so I can continue using VDJ or prepare to move to Traktor 3.
geposted Fri 21 Jul 06 @ 7:40 pm
That's the 1st time I see a user choosing a software for its skin and not for its features!
geposted Fri 21 Jul 06 @ 7:52 pm
Marius,
Have you used the skin?
geposted Fri 21 Jul 06 @ 7:59 pm
Yes, but I won't switch to Traktor if I can't use the skins anymore. Btw, I understand when Traktor asks to remove this skin.
geposted Fri 21 Jul 06 @ 8:27 pm
phillydjPRO InfinityModeratorMember since 2004
Wow Switching for a skin? Why? You can always make your own skin
geposted Sat 22 Jul 06 @ 10:24 pm
