Topic: im byeing
rvd4nowPRO InfinityMember since 2006
`im going to be b uy the softwear soon and i wonted to no witch one do i buy
the one for 150$
or
250$ you guys offer two differt choise what is the best one for me to bye and also i will be trying to buy a good cheap mixer what would be a nice cheap one wit sound effects
geposted Sat 08 Jul 06 @ 12:12 am
the cheaper on, is a discounted internet download version, where you can download instantly after the purchase
the ohter is a boxed version, sent you by mail.
But the software and version is the same :)
geposted Sat 08 Jul 06 @ 12:16 am
what would u recamend
geposted Sat 08 Jul 06 @ 12:19 am
internet version ;)
its priced with a very high discount, and you get the software instantly by download from this website;)
ready to go as soon as you have bought it... no need to wait for the cd comming by mail....
saves you 100 buck too ;)
geposted Sat 08 Jul 06 @ 12:21 am
Yeah, download is the way to go, you can always do as I did & back it up on cdr in case your computer ever crashes;^]
geposted Sat 08 Jul 06 @ 12:57 am
ok no as far as hooking up turn tables what do i need to get and what are soem good turn tables
geposted Sat 08 Jul 06 @ 2:58 am
DJ-ALFPRO InfinityModeratorMember since 2005
You gonna need the Virtual Dj Pro version, 2 Timecode Vinyls and a sound card with 2 stereo inputs like Maya 44 USB or Dj Console Mk2. Technics 1210 are the best decks but pricey, Numark TTX is good also and cheaper one. Choice is yours.
geposted Sat 08 Jul 06 @ 8:22 am
I wouldn't recommend using the mk2 for TCV usage, the latency is unbelievably high. I made that mistake & now I have to wait to get the u46dj. For TCV use you should use either the maya 44 USB or the ESI u46dj;^]
geposted Sat 08 Jul 06 @ 6:17 pm
xantharHome userMember since 2006
It would be nice if you would learn how to spell first :D
geposted Sat 08 Jul 06 @ 6:42 pm
my recommendations if you're buying equipment would be the U46DJ (working fine for me) for the soundcard/interface, as for the decks I'd say Technics but they are costly, so my cheaper alternative would be Stanton direct drives. But in all seriousness, I wouldn't buy decks at all, I'd go for CD decks, anything by Pioneer (CDJ200 is a great cheaper cd deck).
geposted Sat 08 Jul 06 @ 7:53 pm
