What ways do you guys want your music organized? So far, I have, genere, bpm range, playlist, date added. Any other suggestions?
And I'm really excited about getting drag and drop from the manager onto vdj working. I think it will be great to be able to search through your music effectively in the manager, and then dropping it on vdj to play.
Are there any other features you want to see in an external manager?
geposted Tue 11 Jul 06 @ 4:15 pm
pretty colors....im just kidding, it sounds like you pretty much got everything covered. is this a plugin? how about maybe file extension or bitrate
geposted Tue 11 Jul 06 @ 4:56 pm
No, its an external manager. From what I understand vdj's internals arent exposed enough to pull off what i'd like to do.
geposted Tue 11 Jul 06 @ 4:57 pm
I saw in another piece of software that you can click a little search icon next to say an artist and it brings up everything by that artist. not amazing but it becomes handy with the one on the bpm column, where you click the search icon in that column and it brings up everything within a certain range of that bpm (say +/- 4%)
bpm range would be nice, but vdj already does that. well somewhat..
geposted Tue 11 Jul 06 @ 4:59 pm
those are some great suggestions! I appreciate it
geposted Tue 11 Jul 06 @ 5:02 pm
there's another tiny little thing, and it's probably me being petty but...
i like to be able to autosize the columns to fit the content in. that would be a nice little touch.
geposted Tue 11 Jul 06 @ 6:34 pm
fair enough
goodluck blackgold
geposted Tue 11 Jul 06 @ 6:47 pm
I appreciate it. I've gotten pretty far along with it. Got tracks being sorted into various (more importantly Multiple) generes/tags. I have it successfully reading the database/file locations to extract the bpms/length etc...
I need to come up with a good routine for parsing the artists/titles (vdj doesent save them unless you specifically change it). I'd also love to do synced data (change vdj and it shows up in manageR). Is it possible to force vdj to save the db?
I'm going to work on drag/drop and then finally (and should be most simply) the outputting of a directory of shortcuts all sorted into their relevant folders for easy navigation from within vdj.
geposted Tue 11 Jul 06 @ 6:53 pm
Blackgold,
there is a shortcut available to save the database. This shortcut is named "SaveDatabase". I have set it to Ctrl+S. I save regularly also during gigs.
Ewout
Ewout
geposted Tue 11 Jul 06 @ 8:10 pm
thanks for the tip!
geposted Tue 11 Jul 06 @ 9:14 pm
