Forum: Wishes and new features
Topic: Database management
Hi everybody
The Database is very important for all users.
Many hours are used to implement implement it (especially cue points and comments).
--> Don't forget to make regular backups
New features suggestions:
- Is it posible to create a cleaning tool ? (doubloons enlarge it pointlessly)
- Is it possible to get an option to analyse ONLY never analyzed files ? (For not to delete everything done on the existing and already analyzed files).
Thanks to the team
geposted Sun 20 Jun 04 @ 7:09 am
The second question looks a very helpfull feature to me.
It happens quite a lot that you add songs to an existing folder. Now you have to select the new songs yourself end select "Analyse". Now you select your complete drive and all new songs will be anaylysed
Ewout
heres a thought load you song to either player and do a quick refresh. You have to check them anyway right.
