Topic: Mic problems
Hi I have some microphone problems. it just dos´t work!
do you have to do some special installation for it?
kind ragards!
geposted Thu 13 Jul 06 @ 1:12 pm
joetmenPRO InfinityMember since 2005
geposted Thu 13 Jul 06 @ 1:18 pm
ty but have already try that.. it say error on plugin talk over.
the problem is that I can´t talkover or speak in the mic becouse the sound dose not work.. bad english but hope you will understand:)
geposted Thu 13 Jul 06 @ 1:40 pm
xeonPRO InfinityModeratorMember since 2004
Are you sure that your microphone work? Try to plug it in your interal sound card at mic in.
geposted Thu 13 Jul 06 @ 1:57 pm
ya it´s working and the red lamp shows when i speak but no sound comes out...
it say in the istallationbook that I must enable the talkover option in the main tab of controlpanel but can´t find it..
geposted Thu 13 Jul 06 @ 2:24 pm
so you have to open preferencs of your MK2 and there you have to enabe talkover or something like this. I have 1st edition of DJC and it is different. but near the clock in right down corner of screen there must be icon of MK2. double click on it and you get preferences. It is like this with my console :)
geposted Thu 13 Jul 06 @ 4:22 pm
