Forum: Wishes and new features
Topic: !!PROGRAM MIX IN MONITORS!!
AMAZING PRODUCT LADS!!
HOWEVER,
HOW THE HECK DID SOMEONE FORGET TO ADD A MIX OF YOUR PROGRAM AUDIO (WHAT IS PLAYING ON THE SPEAKER OUTPUTS) TO THE OVER-ALL MONITOR MIX!!!
THE WHOLE - "DEFAULT / ACTIVE PLAYER MIX ONLY"- MONITOR MIX SCHEME IS COMPLETELY DAFT IN IT'S NATURE. IN MOST PERFORMANCE SITUATIONS, EITHER AT HOME OR AT SOME OUTDOOR DESERT PARTY IN FRONT OF SEVERAL THOUSAND PEOPLE, I WOULD EXPECT (DEMAND) A DJ-MIX SOFTWARE OF THIS OR ANY CALIBRE TO HAVE A FULLY FUNCTIONAL MONITORING SECTION!!
TO BE HONEST, THIS PRODUCT IS THE FINEST EXAMPLE OF A NON-HARDWARE LEVEL
"DJ DREAM COME TRUE"!! AVAILABLE.
I'VE USED EVERYTHING: DSSDJ, PCDJ, ALCATEC "BPM", MIXVIBES PRO, & NATIVE'S TRAKTOR PLAYER. THIS SOFTWARE (V-DJ), IS A BLESSING TO WORK WITH! I CAN'T WAIT TO PLAY A 10 HOUR PSYTRANCE SET ON THE BEACHES OF GOA, INDIA NEXT SEASON. BUT, FOR THOSE GIGS, I SIMPLY CANNOT USE MORE THAN MY LAPTOP, HARDDRIVE, & HEADPHONES. NO MIXER!
PLEASE, FOR THE SAKE OF V-DJ'S PURITY & SIMPLICITY.
ADD A PROGRAM MIX TO THE MONITOR SECTION!
THANX,
ROB
P.S. IF THIS HAS BEEN ADDED TO THE NEWER VERSION......CHEERS (TO THE TENTH POWER)!
geposted Sat 15 Jul 06 @ 9:16 am
Next time please don't write in CAPS
geposted Sat 15 Jul 06 @ 9:37 am
NO OFFENSE INTENDED, BUT HOPEFULLY TAKEN. I FEEL THAT THIS PRODUCT'S RELEASE OF SEVERAL VERSIONS WITHOUT FIXING THE PROGRAM MIX INTO THE MONITOR SECTION.
IS, IN ITSELF, OFFENSIVE. I FIND NO VALIDITY IN THE ACTIONS OF PAYING FOR MORE THAN THE DEMO VERSION.
UNTILL THE REQUESTS FOR 'A FULL FIX OF THIS DISSABILITY' HAVE BEEN FULFILLED, I CAN ONLY GIVE MY MONEY TO A SOFTWARE THAT HAS ALREADY RELEASED A VERSION 1.0 WITH THIS BASIC & PRIMARY FUNCTION.
SORRY GUYZ! MY OPINION MAY ONLY BE OF ONE ITSELF, BUT, IN THIS OR ANY INDUSTRY
YOU COUNT YOUR MONEY BY ADDING 'ONE' OVER AND OVER 'TILL YOU GET 2,3,4,5,6,7......
THE FEEDBACK FROM MYSELF, AND EVERY OTHER DJ ON THIS FORUM, MAY ONLY BE "AN OPINION", BUT "OPINIONS" ALSO ADD UP, AND EQUAL = "REVENUE"
CROSSING MY FINGERS & MY "$ FIGURES $"!
MAYBE A BETTER VER 4.0?
(NEED A BETA TESTER??)
THANX,
ROB
geposted Sat 15 Jul 06 @ 10:02 am
oops... sorry about that mate!
i guess now i actually owe you two apologies!
fast return message of any kind... cheers!
please know that i truely appreciate this fine software!!
but, when you build the best software around, you realy have to keep it that way.
best regaurds,
rob (no-caps)
geposted Sat 15 Jul 06 @ 10:13 am
phillydjPRO InfinityModeratorMember since 2004
The full version has more features than the trial, the trial is just to give you an idea of what the program runs/ sounds like.
geposted Sun 16 Jul 06 @ 11:30 am
erxonPRO InfinityMember since 2003
A lot of words, not much said.
Question: "THE MONITOR SECTION PROGRAM MIX" would be what?
If by 'monitoring' you are reffering to Pre-Fade Listening (or PFL in short), it's a function that is not included in trial version as one of 'demo limitations'. You might have overlooked the BIG ALL-CAPS FONTS that say that under the audio settings since you prefer capital letters - and a note on that: since ASCII became standard, all-caps sentences are considered shouting (on internet forums, blogs, websites, etc.) and are harder to read as opposed to lowercase sets.
If on the other hand you are not reffering to PFL, please do explain what you mean.
Ps.: A quick search on forum would answer your question regarding beta testers (also many other questions, if you have them). Search example
Best regards.
geposted Sun 16 Jul 06 @ 12:23 pm
