Can someone give some titles of some trance music or other easy music to mix...
Some basic music like Satisfaction and things like that.
Thannk you:)
Thannk you:)
geposted Sat 15 Jul 06 @ 7:07 pm
Theres so much trance music around it's better you google for top 100 trance or dance
geposted Sat 15 Jul 06 @ 7:09 pm
haha yes thats true:)... but what are the easiest?
geposted Sat 15 Jul 06 @ 7:10 pm
Most trance, Dance, House all have a steady tempo there all pretty easy to mix, if you want to learn more you can go to the mix lessons forum http://www.virtualdj.com/forums/15/Mix_lessons.html
geposted Sat 15 Jul 06 @ 7:20 pm
Check my blog for house charts and house is easy to mix :).
geposted Sun 16 Jul 06 @ 8:43 am
I tried some House music, and i experienced that its quit easy to mix
thanks for the comments.
-DJ- Shockwave
-DJ- Shockwave
geposted Sun 16 Jul 06 @ 11:03 am
Keep in mind mixing the easy music isn't gonna improve you a whole lot, eventually you'll have to try the harder stuff
geposted Sun 16 Jul 06 @ 11:10 am
Yes but it's good for a start:)
geposted Sun 16 Jul 06 @ 12:33 pm
True that, well best of luck mixing
geposted Sun 16 Jul 06 @ 12:41 pm
Hey phillydj, how do u get your sig to appear at the bottom of your post?
geposted Sun 16 Jul 06 @ 1:58 pm
i just put it there using the bb code you can search the forums for bb code to understand how it works
geposted Sun 16 Jul 06 @ 5:48 pm
I don't know if bb code is available for "Non licence" users.
Ewout
Ewout
geposted Sun 16 Jul 06 @ 5:56 pm
You've got a point Superstorn I don't know either
geposted Sun 16 Jul 06 @ 6:08 pm
oh ok. Well iv paid for VDJ im just waiting 4 the email
geposted Mon 17 Jul 06 @ 8:20 am
Congrads,, Glad to see you made the choice
geposted Mon 17 Jul 06 @ 9:51 pm
Thanks dude. But..
Becuase i paid using Wire Transfer, it will take a lil longer till i get my email :(
I cant wait!!!!
I cant wait!!!!
geposted Tue 18 Jul 06 @ 3:11 pm
Shockwave, a good starting point for mainstream dance music are compilations like Ultra Dance Series. Most of these type of compilations are mixed but are great for using as a reference. Good luck!
geposted Tue 18 Jul 06 @ 4:05 pm
just find something that starts with a beat. Avoid intros. And use tracks that don't fade out, so that you have to do the fading. Just grab a few tiesto tracks or something like that and just play. The only difference between you and a champion mixer is practice. That's it. Just practice those basic beats.
If you really just starting out, find two tracks with the same BPM too. Try these 2 Darude tracks , 'Music' and 'Be With You'. They are the same BPM and really simple rhythms. Start by playing 'Be With You' and mixing in 'Music' when it's comming to an end. Good luck man, keep us posted.
Remember - LOTS of practice - don't give up
geposted Tue 18 Jul 06 @ 6:43 pm
I don't recommend using these compolations. Many of them are already 'premixed' which makes them very hard to learn on.
geposted Tue 18 Jul 06 @ 6:44 pm
Well thanks alot for your comment:)
I made some beats with trance music., thats not that difficult
geposted Tue 18 Jul 06 @ 7:06 pm
