Link: http://www.sonicstate.com/news/shownews.cfm?newsid=3257
Found this video on the new M-Audio DJ software and TCV, it looks like virtual DJ with an Ableton Live Skin. Another DJ app to add to the ever growing number… But this has ReWire : ) I hope we see this feature in VDJ4
geposted Tue 18 Jul 06 @ 3:51 am
This actually looks more like it would compete with the likes of Finalscratch or Serato. Its doesn't do video either. :)
geposted Tue 18 Jul 06 @ 7:43 am
I really like the fact that you can switch decks, so you only need 1 turntable.
Hope that'll be in vdj4.
geposted Tue 18 Jul 06 @ 6:44 pm
its already there in VDJ 3.4 ;)
So it will defititively still be there in 4.0 ...hehe
geposted Tue 18 Jul 06 @ 7:18 pm
Is it possible to make VDJ 4.0 rewire application? I would love to run VDJ through Ableton and drop loops in perfect sync.
I buy a lot of loops from M-audio and acid, is there a way to import them into VDJ's sampler without have to record them in? What Audio form are VDJ's samples?
geposted Tue 18 Jul 06 @ 10:30 pm
You can definitely import loops without having to record them; as long as they are in any of the VDJ supported formats (wma, mp3...) You just need to load them from the sample box by clicking in the options button and locating the file.
I usually keep all the samples that I edit with another software in the C:Program Files-VirtualDJ-Samples folder and organise them in several sub-folders. That way I can identify vocals, beats, tunes... easily
Let me know if this works for you or I could give you more directions.
geposted Tue 18 Jul 06 @ 11:58 pm
how do you do that in vdj 3.4?
also does anyone know if you can get the timecoded vinyl in the states anywhere?
geposted Wed 19 Jul 06 @ 12:28 am
I was able to load the loops thank you
geposted Wed 19 Jul 06 @ 6:03 am
you can get TCV in the states, its easy, go to products menu at the top of the website.
that toruq program has one vital feature VDJ does not.............
'where it would have been'
theres gotta be a proper word for it but im talking about a loop exit that returns the song position not to where it was when the loop was stareted but 'where it would have been'
the only way to exit a loop and keep the correct timing in VDJ is ether use a long loop and loop it a few times or if your doing a fast loop use a cue point
geposted Thu 20 Jul 06 @ 1:57 am
oh and another feature its got that i suggested for VDJ is quick assign to deck of the traditional scratch noises so you dont have to load up a different mp3 in a deck when its essentialy just a tiny loop over and over again, also that way it never gets to the end of the scratch vinyl
geposted Thu 20 Jul 06 @ 11:33 pm
