Topic: Audigy 2 ZS Platinum Pro Help
Has anyone been able to connect Audigy 2 ZS (Platinum or Pro) to Virtual DJ (latest version) and use the Time Coded Vinyls? Can It be done in ASIO mode? As to send data from the turntables with the TCVs into the SB card inputs, then from the SB card outputs back to the physical mixer, and then from the physical mixer back again to SB card main input (just to name it so) or to an amplifier, either for multichannel upmixing for home using or high power end for a public event, respectively.
Any success? Any better ideas?
geposted Tue 18 Jul 06 @ 10:06 am
TCVs work fine with virtual dj professional edition!
demo version has some limitation, and you cannot use it so well...
bye
I use tcvs and audigy2 zs platinum and works flawelesly, buy vdj pro send me a pm and I will send you my configuration and my registry since is neccessary to modify it , Manquin DJ.
http://www.virtualdj.com/purchase/
