Will vdj play automatically if I have a playlist videos. Will it mix from one to the other as each video ends? Thanks
geposted Tue 18 Jul 06 @ 2:48 pm
yes, virtualdj can do it with "automix".
if you want to know other features of this software, you can go here.
regards
regards
geposted Tue 18 Jul 06 @ 3:05 pm
You need to move it over to the playlist area on the right - click the star to make it mix automatically.
It's difficult to work with sometimes, for some people, as it either cuts the records short or starts them in the middle - or just plays them like an LP - you may need to fiddle around with the settings in the Config menu - I've managed to set the Crossfader to Smooth and the Fade Length to Max - but it cuts the records short - any other setting sounds odd.
geposted Wed 19 Jul 06 @ 11:14 am
