Hello Jpboggis or someone else!
I'm working on my own dac3 mapper and it looks promising. I have configured all the buttons without problems.
Next I'd like to make jogwheel as versatile as possible.
In jpboggis dac mapper 1.2 there is
shift+jogwheel for file browsing and
shift+folder+jogwheel for folder browsing
they are so great but how could i make them to work in my own mapper?
Also i'd like to add following:
CP + jogwheel for zooming in and out rhythm window
R + jogwheel for adjusting CBG.
Now i have code:
Is it just as easy as changing action "jogwheel" to another?
I have tomorrow first gig with dac-3 and i'd like to get everything mapped before that...
Now i have code:
HRESULT CDAC3DefaultMapper::OnJog(int chan,int jog)
char st[64];
char* channel=chan?"2":"1";
SendAction("jogwheel",channel,IntToStrRelative(jog*2,st),true);
return S_OK;
geposted Fri 21 Jul 06 @ 3:28 pm
To get the jogwheel to perform different actions based on combinations of buttons being held down, you need to store the status of each relevant button in a variable. The default mapper already does this for SHIFT and CP:
...So to allow file browsing with SHIFT+jogwheel, it's simply a matter of testing whether SHIFT is pressed or not, e.g:
For other button combinations, you will need to add a variable to store their current state, e.g:
...And define a the rdown variable in the private section:
Also, I do a test on Song[chan].Playing so that the jogwheel can perform a fine pitchbend while playing.
case DAC3_SHIFT:
shift[chan]=(down!=0);
break;
case DAC3_CP:
cpdown[chan]=(down!=0);
break;
char st[64];
if(shift[chan]) {
SendAction("browser_updown",channel,(jog < 0) ? "-1":"1",true);
} else {
return S_OK;
case DAC3_R:
rdown[chan]=(down!=0);
SendAction("pitch_reset",channel,NULL,down);
break;
bool shift[2],cpdown[2],rdown[2];
geposted Sat 22 Jul 06 @ 9:58 pm
