Is there a way to convert a .vdj sample to a wav file?
geposted Sun 23 Jul 06 @ 12:15 am
why not just play it and record it while it's playing
geposted Sun 23 Jul 06 @ 12:24 am
If I remember correctly the samples are ogg files. So if you make a copy of the sample file and rename in to ogg, then you could play it in winamp or Windows media player. You could also convert it then to wav, or mp3.
Ewout
Ewout
geposted Sun 23 Jul 06 @ 2:05 pm
your right superstorm , they should be ogg files
geposted Sun 23 Jul 06 @ 6:35 pm
how do you go about converting it though? that was what i was wondering. I wanted to be able to use it on other things as well.
geposted Mon 24 Jul 06 @ 1:05 am
just google for ogg to wave or ogg to mp3 but, remember that you have to change the extension on the file from .vdj to .ogg
geposted Mon 24 Jul 06 @ 1:13 am
