Hi, i was just wondering do you use or how you use TK2 Filter.
I use it to simulate low pass filter. When making transition from deck 1 on deck 2, on deck 2 enable TK2 Filter, with right click set yellow line (quality factor or res) to 1/4 or less, close to bottom and put a red dot in upper left corner to isolate all sounds. Put a crossfader on the middle and start moving red dot slowly to the right. Between 20 and 200hz remove some bass on mixer because it sound bad and after 200, very slowly moving red dot to the end, depends of the song. then make similar or other effect on deck 1 and there is ideal transition.
geposted Sun 23 Jul 06 @ 4:35 pm
Pozdrav Kiki :)
I don't use it because it stress system a lot and it doesn't have nice sound, can be dangerous for very powerfull speakers in a club. I prefer flanger (any type), it is very good for drop-outs or transitions. I use Beatgrid and new Beatbox a lot, and Reverse is the best.
geposted Sun 23 Jul 06 @ 4:50 pm
It's optimised like shit, but it isn't bad. If I had sources, I would improve it! It must be "smoother" to preserve loud speakers from damages.
geposted Sun 23 Jul 06 @ 8:03 pm
Now you have access to many source codes, but not the Tk2 filter... But many others:)
http://www.virtualdj.com/addons/view.html?type=sound%20effect%20source%20code
(Experienced users only)
geposted Sun 23 Jul 06 @ 8:07 pm
Maybe try something similar to what I do with a mixer. Like a 'bass crossfader' with the main crossfader in the middle. That gets rid of the 'double bass' thing that happens if you leave them both on normal. I think you can do it with vdj...
geposted Sun 23 Jul 06 @ 8:36 pm
LOOOOOL :) Try to beatmatch, that way you will not have "double bass"
i know TK2 filter is poorly optimised, by my opinion it only works well when yellow line is on the bottom, that way you will not burn amps or speakers :)
geposted Mon 24 Jul 06 @ 1:15 am
@Norway: Thanks Rune! I'll keep the 3rd star...
@DJ Niems: Band crossfaders are already available for VDJ.
geposted Mon 24 Jul 06 @ 3:12 pm
