Can anyone suggest a soundcard for a laptop that will let me prelisten to songs using headphones.
Thanks
Thanks
geposted Wed 26 Jul 06 @ 12:55 pm
You can use any 4 channel sound card, I use Sound Blaster Live 24-bit USB and it is around 70 euros. If you wonna go with TCV's than ESI U46DJ is your best choice, around 170 euros.
geposted Wed 26 Jul 06 @ 4:13 pm
DJ ALF is correct. U46Dj is the best choice.
geposted Wed 26 Jul 06 @ 4:26 pm
ESI U46Dj at 95€ it's good http://www.thomann.de/thoiw8_esi_u46_dj_prodinfo.html
geposted Wed 26 Jul 06 @ 4:36 pm
If you are not using Time Coded Vinyl go with the Echo Indigo. It is a PMACIA Card with two out puts. One for monitoring the other goes to the house speakers. it costs $179.
geposted Wed 26 Jul 06 @ 5:02 pm
