Well,
VDJ 4 will support BCD2000. So i guess it would be nice someone to create a skin with BCD view. I know nothing about skins, but i noticed that in the xylio directory, two files similar to VDJ skin files. There is a bmp file, the way Virtual bmps files are, and an xml file that could help someone to start with. Some commands could be similar.
If anyone would like to create such askin, i would gladly send him the files.
Thanks
Thanks
geposted Sat 29 Jul 06 @ 12:34 am
@djdad............check my blog ( below Stanton skin ).........this is what I've done so far...............this is just the artwrork of the controler, next week I will have a complete layout of the BCD 2000 skin.....
If you can do the xml file, then it would be perfect, cause i don't know sh@#$ about that......jajajajaja
Peace !!!
Peace !!!
geposted Sat 29 Jul 06 @ 1:13 am
