Does anyone know of a way to modify the center frequencies of the 3 bands of the EQ built into each deck of VDJ?
Particularly, I would like to lower the center frequency of the bass band. It is a little too high for my taste... when using it to kill the bass, it takes too much of the rest of the music with it, especially the vocals.
geposted Sat 29 Jul 06 @ 5:35 am
To me that sounds like a plugin like the isolator, i personally can't figure it out really, but you have the options to select what ranges you want for the lows, middle, highs etc
geposted Sat 29 Jul 06 @ 5:48 am
Try using the 32 eq plugin which you can find as an effect download.
geposted Sun 30 Jul 06 @ 5:28 pm
I requested it in the past, but still no response. Maybe a suggestion for new sound engine in V4.
geposted Wed 09 Aug 06 @ 12:12 pm
