Forum: VirtualDJ Plugins
Topic: VST compressor/Loudness maximizer?
Hi,
Does anybody have a favourite VST compressor? Just to sqeeze everything i can out of the sound system.
First i was looking at hardware to do this, but what i really want is a dbx driverack pa and they're about £500 in the UK!
Any help would be really appriciated.
geposted Thu 03 Aug 06 @ 2:39 pm
TexZKPRO InfinityMember since 2005
You can find a simple electronic scheme on http://www.audiomaster.it/tutorial/compressorielimiter.htm, but there aren't some values... I also have two projects from the magazine "Nuova Elettronica", complete with schemes, description and instructions to solder the kit (which you can buy from http://www.nuovaelettronica.it). The only problem is that everything is in Italian, but is sound as good as a professional compressor and costs only €60.40 (without trasport).
geposted Fri 04 Aug 06 @ 6:31 pm
Thanks for the suggestion, but if i can find a software one, it should be alot cheaper (and lighter!) than getting an actual unit to do it.
I think i'd probably mange to break it if i tried to build it from a kit anyway! :)
geposted Mon 07 Aug 06 @ 2:21 pm
