hey fellas.i got a simple question...what are the settings for recordin the mixes i make..i have tcv's, mixer, ud6dj and etc.....and what are the settings for the timecoded vinylson the SOUNDCARD tab on config
thnx in advance
thnx in advance
geposted Fri 04 Aug 06 @ 7:04 am
The simple answer is you need a Pro version, you can use only one TCV and one output on your sound card, so no pre-listening. You can record your mix using a crossfader in VDJ skin in demo version, for more, buy the program ;).
geposted Fri 04 Aug 06 @ 7:35 am
Have you bought the timecode vinyls here on the site? I was wondering while you dont have the vinyl logo's in your profile.
Like dj Alf is saying, your demo version is only capable of using 1 time code vinyl and only has the mix output. On top of that the demo version could only be used for 20 days.
If you would like to have the full capabillities (2 time code vinyls, and connect your u46dj to a mixer, or use it for prelistening) you will need the full version.
Ewout
Ewout
geposted Fri 04 Aug 06 @ 6:35 pm
