ok...i want 2 mix a song with another song.
meaning...
i dont want the other songs music...i just want the artists' voice...
So basically...Only the one song mixed with the other song im trying to mix w/ the voices and chorus (not the music)
can someone tell me how to do this?
meaning...
geposted Fri 04 Aug 06 @ 11:42 pm
Yes, this is easy. Don't use the song where you only want the voice of, but use the acapella version.
A music song is just like a cake. You add sugar, apples, butter and so on. When the cake is finished you never can get all the suger, you put in before, out of it. So once in never get out. There are some voice removing filters, but they only work partly. Getting the acapella is probably much easier.
Ewout
Ewout
geposted Sat 05 Aug 06 @ 12:20 am
