Forum: Old versions
Topic: Hercule, scratch & noob
Would it be possible for someone to add (or point to) a small tutorial on scratching with DJ Console (w. VDJ 2 full).
I cannot manage to obtain anything decent... I don't know if it's a matter of sample or technic (probably both).
I have to add that I'm completely newbie.
geposted Fri 25 Jun 04 @ 6:24 am
hi there... :)
scratching is very hard (good scratch), and needs practice :)... it's working fast and in tempo, making good sounds with crossfader to cut of and make effects...
there are some good "beginners how too scratch" videos posted at "mix lessons forum" here... that a look at try, and practice ... :)
scraching with hercules is very cool - but it takes practice ;) lots of... lol :)
it's going to be a bit difficult on hercules, althought you can make some good and decent scratch sounds, it's a bit different than vinyl/xp10 becasue it doesn't have a "tactical plate" (stops and stay stopped if you put your finger on it), it has a very sensitive jogwheel (great work from the team!!!)... so it responds very good to touch on the wheel - direction and speed.. practice and you can make good sounds :)
good luck... (there are many good guides at the net by the way)
dj in norway
Thank you very much.
Is there "some kind of sample" that are easier to learn with (bass ? voice ? loud or low ?)
voice sample or accapella is the best for good sounding scratch... and esiest to start with :)
many dj's have sample vinyl (with a lot of voice samples saying for example "yeah" etc) that they use for nice scratch sounds... you can find many accapelas or samples on the net for the use :)
or even some scratch with a sample scratch sound... a bit "faking it", but sound great :)
when getting more pro, try breakbeats/hiphop (harder)... or other genre ... try turning down/off bass and maybe also high on the track u are scratching with... play around :)
