In the left cd-Speler you can you click to the first beat
how can I the right cd-Speler also let of the beginning of the beat ?
geposted Thu 17 Aug 06 @ 6:52 pm
Hmm...
Not 100% sure what you mean. But VDJ have same behaviour for both decks.
If you right-click on the stop button in skin, VDJ will auto cue up at the first beat... both on the left and right deck.
If that is what you are looking for :)
geposted Thu 17 Aug 06 @ 9:51 pm
I try it later, now I'm at my work ;)
Thanks...
Thanks...
geposted Fri 18 Aug 06 @ 10:55 am
I have try it, but this does not work?
geposted Fri 18 Aug 06 @ 6:56 pm
Dude, please use the standard terms, and try making a sentence.
What do you mean by cd-Speler? a deck (virtual turntable)? a cd player with timecode?
What do you mean by 'click to the first beat'? Which button (or shortcut) is 'clicked', what action you want to make, etc.
I can only guess you're having cueing problems, but as much as I want to I can't help you if I don't know what's the issue.
Any other language maybe?
Regards.
Regards.
geposted Fri 18 Aug 06 @ 8:45 pm
If I click twice in the left deck on stop then shut he to the first beat,
this want I also this way have in the right deck!
Is this possible?
Is this possible?
geposted Sat 19 Aug 06 @ 7:38 pm
it works exactly the same on the right deck...
at least at my pc
Are you not getting the same results on right deck?
at least at my pc
geposted Sat 19 Aug 06 @ 8:15 pm
No in my right deck the bud is stopper and dubble clicks work there not ?
geposted Sun 20 Aug 06 @ 10:33 am
Firstly, are you using the default skin?
Secondly, have you loaded the same song in both players? If not one song may have a cue in it, the other may not. Try loading the same song in both players.
geposted Mon 21 Aug 06 @ 9:34 am
No sorry I using the Pioneer MKII skin bud now I try the DAC 3 skin and it's working !
geposted Mon 21 Aug 06 @ 10:06 am
hmm.. weird
might be something with that skin then...
geposted Mon 21 Aug 06 @ 6:13 pm
Yes I think it, something is not well with the Pioneer MKII Skin ?
Can you test him differently also ?
geposted Mon 21 Aug 06 @ 7:14 pm
