how can u control the speed of the fader in a forced mix or auto mix
I' ve tried the fade length in the config setting, but it does not work. the fader sometimes moves at a blazing speed, which does not mix the two songs even if beatlocks are on. Other times it does great and gradual fade.?? can't tell what is causing the two differences with the same settings on the same computer
geposted Mon 21 Aug 06 @ 11:44 pm
use FORCE FADE
set FADE LENGTH
and set AUTO BPM to SMART or DISABLED
(disabled = no beatmatch, only fade smart= beatmatch only those that are well fitted for matching)
set FADE LENGTH
geposted Tue 22 Aug 06 @ 12:46 am
