for the record, i love the program. i used the demo on my home pc for 4 hours a session with no freeze/skips.
since i downloaded the full version on a laptop i have had freeze/skips every time i run Vdj2.0. (including 2 weddings, not good)
i performed every tip the was posted by dj coco (support team) and upgraded 640MB's of RAM. The laptop also had XP reinstalled on in before vdj2.0 was bought & installed.
i will install the program on my home pc and if it continues to freeze/skip i can only conclude that the program does not work effectively, am i wrong?
PS thanks for all your responses so far, i really want this program to work.
darby k. place
darby k. place
geposted Tue 29 Jun 04 @ 2:29 am
i would like to install vdj2.0 on my home PC to see if it my laptop which is causing the freeze/skips or if it is the program.
please email me the link to download the vdj2.0 software so that i may figure out where the problem is.
PS i have an error message that says: ATI control panel failed to initialize because no ATI drive is installed / in not working properly. The ATI control panel will now exit.
thank you again,
darby k. place
thank you again,
darby k. place
geposted Tue 29 Jun 04 @ 2:53 am
Please contact : http://www.virtualdj.com/support/e-service/
">e-service
Thanks
Thanks
geposted Tue 29 Jun 04 @ 3:17 am
Hi Dj !
sorry to hear that you have a skip problem, but let me tell you that in the 99,99% of the reported cases, the problem came from the user´s pc (software, internal hardware or an external hardware problem)
So i suggest you to take a look into your computer software (windows, icq, etc) and hardware to see if everything works properly.
Hope it helps.
Hope it helps.
geposted Wed 30 Jun 04 @ 7:23 pm
How much RAM are you running on the laptop ? Need 512Mb to be comfortable.
geposted Sat 03 Jul 04 @ 4:46 am
