Hi All
After installing the new v4 a brown # symbol has appeared next to some of my songs.
Can anyone tell me what this is?
Many thanks
davexx
Many thanks
davexx
geposted Fri 25 Aug 06 @ 10:35 am
Really.. how bizarre - is it just in the 'local database' or do you get it when you browse using file browser .... could try renaming your xml and vdjdatabase files then rebuild.
If possible post a screenshot so we can see exactly what you mean.
geposted Fri 25 Aug 06 @ 10:41 am
Ah...
Its not a # sign - it just means the bpm is to far off for auto syncing..
check this thread..
http://www.virtualdj.com/forums/54391/General_Discussion/_Not_Equal__sign_on_tracks___.html
check this thread..
geposted Fri 25 Aug 06 @ 10:48 am
Brilliant, many thanks Nick.
geposted Fri 25 Aug 06 @ 10:52 am
no probs...
geposted Fri 25 Aug 06 @ 11:02 am
Its just another exciting new feature.
So "litle" but so usefull.
Want more... its icon -and the other song icons too- are now skinnable...
geposted Fri 25 Aug 06 @ 11:58 am
yeah, i noticed this too. you can completely customise VDJ now (if you're have basic photoshop and coding skills) to fit your exact requirements. that's gotta be a selling point right there.
geposted Fri 25 Aug 06 @ 12:00 pm
