Can you Search with TCV ? and if so do i need the latest version of TCV ?
Thanks
Thanks
geposted Fri 25 Aug 06 @ 1:16 pm
wait and see in Numark Virtual Vinyls, comming very very soon ;)
geposted Fri 25 Aug 06 @ 1:54 pm
Thanks for the quick reply great up date !!!!!!!!!!!!
geposted Fri 25 Aug 06 @ 1:58 pm
just needle drop quite near to the end of the vinyl and if will take you to controling the browser up down and then needle drop back towards the start and the track will load and TCV will be 'Live'
(im using the old vinyl)
geposted Fri 25 Aug 06 @ 2:39 pm
yupp ;) that works too
geposted Fri 25 Aug 06 @ 3:46 pm
I love this feature, it's superb (just make sure you have track playing security disabled first) :D
geposted Fri 25 Aug 06 @ 6:39 pm
wouldn't you want security "enabled",.. not disabled?
geposted Fri 25 Aug 06 @ 6:52 pm
I suppose it depends on everyones preferences, if you're live then definitely. At home it's more convenient to have it disabled because the feature's been implemented so smoothly that you're unlikely to ever accidently select a track without putting a two inch scratch across your tcv, i.e. bashing the tonearm across to the end of the vinyl).
Great feature anyway, especially for those who want to do everything from their decks and mixer.
geposted Fri 25 Aug 06 @ 7:01 pm
Why Do you say wait n see. Is Numark's vynil different? Cause I just ordered new vynil yesterday and if I Numarks is gonna be better or different, what's was the point of me ordering? I could have just waited. Is Numarks Virtual Vynil gonna be capable of some things VDJ 4.0 isn't capable of?
geposted Thu 28 Sep 06 @ 9:54 pm
For now the vinyls are the same. Just differnt labels and packing.
geposted Thu 28 Sep 06 @ 10:34 pm
What do you mean for now? ;)
geposted Thu 28 Sep 06 @ 11:20 pm
da da daaaaaaa, what do they mean???
its prety simple, for now, the TCVs are the same........... this may or maynot change in the future
geposted Fri 29 Sep 06 @ 2:42 am
Bu*****t, I can't get jiggy with this s**t!
geposted Fri 29 Sep 06 @ 4:07 am
